The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version. SANtricity CLI volume configuration commands 05/27/2025 Contributors Suggest changes Create a GitHub issue Send us an email PDFs PDF of this doc site Collection of separate PDF docs Creating your file... This may take a few minutes. Thanks for your patience. Cancel Your file is ready OK The following list of volume configuration commands are available for your E-Series storage system. Disk pool commands Create disk pool Delete disk pool Enable disk pool security Reduce disk pool capacity Set disk pool Set disk pool (modify disk pool) Show disk pool Start Disk Pool Full Provisioning Start Disk Pool Resource Provisioning Start disk pool locate Stop disk pool locate Host topology commands Create host Create host group Create host port Delete host Delete host group Delete host port Set host Set host channel Set host group Set host port Show host ports Show storage array host topology Internet storage name service (iSNS) commands Set storage array Set storage array iSNS registration Set storage array iSNS server IPv4 address Set storage array iSNS server IPv6 address Set storage array iSNS server listening port Set storage array iSNS server refresh Start storage array iSNS server refresh ISCSI extension for RDMA (iSER) commands Reset storage array iSER baseline Save storage array iSER statistics Set iSER target ISCSI commands Create iSCSI initiator Delete iSCSI initiator Diagnose controller iSCSI host cable Reset storage array iSCSI baseline Save storage array iSCSI statistics Set iSCSI initiator Set iSCSI target properties Show current iSCSI sessions Show storage array negotiation defaults Show storage array unconfigured iSCSI initiators Start iSCSI DHCP refresh Stop storage array iSCSI session Volume commands Check volume parity Create Volume Mapping Clear volume reservations Clear volume unreadable sectors Create RAID volume (automatic drive select) Create RAID volume (free extent based select) Create RAID volume (manual drive select) Create volume in disk pool Delete volume Delete volume from disk pool Increase capacity of volume in disk pool or volume group… Initialize thin volume Recover RAID volume Remove volume LUN mapping Repair volume parity Repair Data Parity Save Check Volume Parity Job Parity Errors Set thin volume attributes Set volume attributes for a volume in a disk pool… Set volume attributes for a volume in a volume group… Set volume mapping Show Check Volume Parity Jobs Show thin volume Show volume Show volume action progress Show volume performance statistics Show volume reservations Start check volume parity job Start volume initialization Stop Check Volume Parity Job Volume group commands Create volume group Delete volume group Enable volume group security Revive volume group Set volume group Set volume group forced state Show volume group Show volume group export dependencies Show volume group import dependencies Start volume group defragment Start volume group export Start Volume Group Full Provisioning Start Volume Group Resource Provisioning Learn about volume group migration (CLI only) Start volume group import Start volume group locate Stop volume group locate
