Delete consistency group - SANtricity CLI
The delete consistencyGroup command deletes a snapshot consistency group.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
This command works in two ways:
You can delete both the consistency group and the repository volumes contained by the consistency group.
You can delete only the consistency group and leave the repository volumes that are contained by the consistency group intact.
Syntax
delete consistencyGroup ["consistencyGroupName"]
[deleteRepositoryMembers=(TRUE | FALSE)]
Parameter
| Parameter | Description |
The name of the snapshot consistency group that you want to delete. Enclose the snapshot consistency group name in double quotation marks (" ") inside square brackets ([ ]). |
The setting to delete on or retain the repository volumes. To delete the repository volumes, set this parameter to |
Minimum firmware level
7.83
