SANtricity commands
Create initiator - SANtricity CLI
Contributors netapp-driley
The create initiator command creates the initiator object.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
Note
This command replaces the deprecated Create iSCSI initiator command.
Note
This command is only applicable to iSCSI, iSER, NVMe over RoCE, NVMe over InfiniBand, and NVMe over Fibre Channel.
Syntax
create initiator identifier="initiatorQualifiedName" userLabel="initiatorName" host="hostName"
interfaceType=(iscsi | iser | nvmeof) [chapSecret="securityKey"]
Parameter Description
identifier
Allows you to specify the identifier qualified name (such as iqn or nqn) to create an initiator . Enclose the identifier in double quotation marks (" ").
userLabel
Allows you to specify a user label for the initiator. Enclose the name in double quotation marks (" ").
host
Allows you to specify the host name where the initiator is installed. Enclose the name in double quotation marks (" ").
interfaceType
Allows you to specify which interface type the initiator is for. Valid choices are: iscsi, iser, or nvmeof.
chapSecret
Allows you to enter the security key that you want to use to authenticate a peer connection. Enclose the security key in double quotation marks (" "). This parameter is applicable only to iSCSI and iSER host interface types.
Minimum firmware level
8.41
