Create storage array syslog configuration - SANtricity CLI
The create storageArray syslog command allows you to archive audit logs onto an external syslog server. After a connection is established between the storage array and syslog server, audit logs are automatically saved to the syslog server.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Syntax
create storageArray syslog serverAddress="<address>" port=<port> protocol=("udp" | "tcp" | "tls") components=(componentName=("auditLog") ...)
| Parameter | Description |
Syslog receiver hostname or IP address. |
Syslog receiver port number. |
Syslog transmission protocol. Acceptable values include udp, tcp, or tls. |
List of component entries that will be logged to the syslog server. Currently, only audit logs are supported. |
Component name; currently only "auditLog" is supported. |
Example
SMcli -n Array1 -c "create storageArray syslog serverAddress=\"192.168.2.1\" port=514 protocol=\"udp\" components=(componentName=\"auditLog\");" ID: 331998fe-3154-4489-b773-b0bb60c6b48e Server Address: 192.168.2.1.com Port: 514 Protocol: udp Components 1. Component Name: auditLog SMcli completed successfully.
Minimum firmware level
8.42
