SANtricity commands
Start tray locate - SANtricity CLI
Contributors netapp-driley
The start tray locate command locates a tray by turning on the indicator light.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
Use the stop tray locate command to turn off the indicator light for the tray.
Syntax
start tray [trayID] locate
Parameter
Parameter Description
tray
The tray that you want to locate. Tray ID values are 0 to 99. Enclose the tray ID value in square brackets ([ ]).
Minimum firmware level
6.10
