SANtricity commands
Re-create external security key - SANtricity CLI
Contributors netapp-driley
The recreate storageArray securityKey command regenerates a storage array security key for use with the external security key management feature.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Security Admin role.
Context
Note
This command applies only to external key management.
Syntax
passPhrase="passPhraseString"
file="fileName"
[deleteOldKey=(TRUE | FALSE)]
Parameter Description
passPhrase
A character string that encrypts the security key so that you can store the security key in an external file. Enclose the pass phrase in double quotation marks (" ").
file
The file path and the file name that has the security key. For example:
file="C:\Program Files\CLI\sup\drivesecurity.slk"
Note
The file name must have an extension of .slk.
deleteOldKey
Set this parameter to TRUE to delete the old security key from the external key management server after the new security key is created. The default is FALSE.
Notes
Your pass phrase must meet these criteria:
  • The pass phrase must be between eight and 32 characters long.
  • The pass phrase must contain at least one uppercase letter.
  • The pass phrase must contain at least one lowercase letter.
  • The pass phrase must contain at least one number.
  • The pass phrase must contain at least one non-alphanumeric character, for example, < > @ +.
Note
If your pass phrase does not meet these criteria, you will receive an error message.
Minimum firmware level
7.70
11.73 adds the deleteOldKey parameter.
