Create read-only snapshot volume - SANtricity CLI
The create snapVolume command creates a read-only snapshot volume for the snapshot images of a base volume. To change a read-only snapshot volume to a read/write volume, use the set snapVolume convertToReadWrite command.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
You cannot use this command for a snapshot image that is used in online volume copy. |
Syntax
create snapVolume userLabel="snapVolumeName"
snapImageID="snapCGID:imageID"
readOnly
| Parameter | Description | ||
The name that you want to give to a snapshot volume. Enclose the snapshot volume name in double quotation marks (" "). |
The name of a snapshot image that you want to add to the new read-only snapshot volume. The name of a snapshot image is comprised of two parts:
The identifier for the snapshot image can be one of these:
Enclose the snapshot image name in double quotation marks (" "). |
This parameter sets the snapshot volume to read-only. This parameter is actually a Boolean; however, in the context of this command, the Boolean value is always
Notes
You can use any combination of alphanumeric characters, underscore (_), hyphen (-), and pound (#) for the names. Names can have a maximum of 30 characters.
The identifier of a snapshot image has two parts separated by a colon (:):
The name of the snapshot group
The identifier of the snapshot image
For example, if you want to create a read-only volume named engData1 using the most recent snapshot image in a snapshot group that has the name snapGroup1, you would use this command:
create snapVolume userLabel="engData1" snapImageID="snapGroup1:newest" readOnly;
Minimum firmware level
7.83
