Configure iSER over InfiniBand ports
PDF of this doc site
Creating your file...
If your controller includes an iSER over InfiniBand port, you can configure the network connection to the host. The configuration settings are available from the Hardware page or the System page.
Your controller must include an iSER over InfiniBand port; otherwise, the iSER over InfiniBand settings are not available in System Manager.
You must know the IP address of the host connection.
You can access the iSER over InfiniBand configuration from the Hardware page or from Settings › System. This task describes how to configure the ports from the Hardware page.
The iSER over InfiniBand settings and functions appear only if your storage array's controller includes an iSER over InfiniBand port. |
Select Hardware.
If the graphic shows the drives, click Show back of shelf.
The graphic changes to show the controllers instead of the drives.
Click the controller with the iSER over InfiniBand port you want to configure.
The controller's context menu appears.
Select Configure iSER over InfiniBand ports.
The Configure iSER over InfiniBand Ports dialog box opens.
In the drop-down list, select the HIC port you want to configure, and then enter the IP address of the host.
Click Configure.
Complete the configuration, and then reset the iSER over InfiniBand port by clicking Yes.
