Delete trusted certificates
PDF of this doc site
Creating your file...
You can delete any of the user-imported certificates.
You must be logged in with a user profile that includes Security admin permissions. Otherwise, certificate functions do not appear.
If you are updating a trusted certificate with a new version, the updated certificate must be imported before you delete the old certificate.
You might lose access to the system if you delete a certificate used to authenticate the storage array's management certificates or LDAP server before you import a replacement certificate. |
This task describes how to delete user-imported certificates. Predefined certificates cannot be deleted.
Select Settings › Certificates.
Select the Trusted tab.
The table shows the storage array's trusted certificates.
From the table, select the certificate you want to remove.
Click Uncommon Tasks › Delete.
A Confirm Delete Trusted Certificate dialog box opens.
Type
delete
in the field, and then click Delete.
