View hardware components
The Hardware page provides sorting and filtering functions that make it easier to find components.
Select Hardware.
Use the functions described in the following table to view hardware components.
| Function | Description | ||
Front and back shelf views |
To switch between front and back shelf views, select either Show back of shelf or Show front of shelf from the far right (the link that appears depends on the current view). The front view shows drives and any empty drive bays. The back view shows the controllers, and any IOM (ESM) modules, power/fan canisters, or empty controller bays. At the bottom of the page, you can also select Show all front or Show all back. |
Drive view filters |
If the storage array contains drives with different types of physical and logical attributes, the Hardware page includes drive view filters. These filter fields help you quickly locate specific drives by limiting the drive types displayed on the page. Under Show drives that are…, click the filter field on the left (by default, shows Any drive type) to see a drop-down list of physical attributes (for example, capacity and speed). Click the filter field on the right (by default, shows Anywhere in the storage array) to see a drop-down list of logical attributes (for example, volume group assignment). You can use these filters together or separately.
Legend |
The components are displayed in certain colors to depict their role states. To expand and collapse the descriptions of these states, click Legend. |
Show status icon details |
The status indicators can include text descriptions for availability states. Click Show status icon details to show or hide this status text. |
Shelf/shelf icons |
Each shelf view provides a list of related commands, along with properties and status. Click Shelf to see a drop-down list of commands. You can also select one of the icons along the top to see status and properties for individual components: controllers, IOMs (ESMs), power supplies, fans, temperature, batteries, and SFPs. |
Shelf order |
The shelves can be rearranged on the Hardware page. Use the up and down arrows on the top right of each shelf view to change the top/bottom order of shelves. |
