SANtricity software
View hardware components in SANtricity System Manager
Contributors netapp-driley netapp-ivanad netapp-jolieg
The Hardware page provides sorting and filtering functions that make it easier to find components.
Steps
  1. From the left panel, select Hardware.
  2. Use the functions described in the following table to view hardware components.
Function Description
Drives, controllers, and components views
To switch between drive and controller shelf views, select menu:Hardware[Drives] or menu:Hardware[Controllers and components] from the left panel. The Drives view shows drives and any empty drive bays. The Controllers and components view shows the controllers, and any IOM (ESM) modules, power/fan canisters, or empty controller bays. On the Drives view, you can also select Show all drives.
Drive view filters
If the storage array contains drives with different types of physical and logical attributes, the Hardware page includes drive view filters. These filter fields help you quickly locate specific drives by limiting the drive types displayed on the page. Under Show drives that are…​, click the filter field on the left (by default, shows Any drive type) to see a drop-down list of physical attributes (for example, capacity and speed). Click the filter field on the right (by default, shows Anywhere in the storage array) to see a drop-down list of logical attributes (for example, volume group assignment). You can use these filters together or separately.
Note
If the storage array contains drives that all share the same physical attributes, the Any drive type field on the left does not appear. If the drives are all in the same logical location, the Anywhere in the storage array field on the right does not appear.
Legend
The components are displayed in certain colors to depict their role states. To expand and collapse the descriptions of these states, click Legend.
Show status icon details
The status indicators can include text descriptions for availability states. Click Show status icon details to show or hide this status text.
Shelf/shelf icons
Each shelf view provides a list of related commands, along with properties and status. Click Shelf to see a drop-down list of commands. You can also select one of the icons along the top to see status and properties for individual components: controllers, IOMs (ESMs), power supplies, fans, temperature, batteries, and SFPs.
Shelf order
The shelves can be rearranged on the Hardware page. Use the up and down arrows on the top right of each shelf view to change the top/bottom order of shelves.
