SANtricity software
Re-synchronize mirror consistency group manually
You can manually start re-synchronization for all mirrored pairs within a mirror consistency group.
Steps
  1. Select Storage › Asynchronous Mirroring.
  2. Select the Mirror Consistency Groups tab.
    The Mirror Consistency Group table appears and displays all the mirror consistency groups associated with the storage array.
  3. Select the mirror consistency group that you want to re-synchronize, and then select More › Manually resynchronize.
    The system displays a confirmation.
  4. Select Yes to confirm.
Results
The system performs the following actions:
  • Initiates re-synchronization of data on all of the mirrored pairs within the selected mirror consistency group.
  • Updates modified data from the local storage array to the remote storage array.
