SANtricity software
Edit access token settings
You can edit settings for access tokens, which includes the expiration times and the ability to create new tokens.
Steps
  1. Select Settings › Access Management.
  2. Select the Access Tokens tab.
  3. Select View/Edit Access Token Settings.
  4. In the dialog box, you can perform one or both of these tasks:
    • Enable or disable token creation.
    • Change the expiration of existing tokens.
      Note When you de-select the Enable access tokens setting, it prevents both token creation and token authentication. If you later re-enable this setting, unexpired tokens can be re-used. If you want to permanently revoke all existing tokens, see Revoke access tokens.
  5. Click Save.
