SANtricity software
Add syslog servers for alerts
You can add a maximum of five servers for syslog alerts.
Before you begin
  • The syslog server address must be available. This address can be a fully qualified domain name, an IPv4 address, or an IPv6 address.
  • The UDP port number of the syslog server must be available. This port is typically 514.
Steps
  1. Select Settings › Alerts.
  2. Select the Syslog tab.
  3. Select Add Syslog Servers.
    The Add Syslog Server dialog box opens.
  4. Select Add another syslog server.
  5. Enter information for the syslog server, and then click Add.
    • Syslog Server Address — Enter a fully qualified domain name, an IPv4 address, or an IPv6 address.
    • UDP Port — Typically, the UDP port for syslog is 514.
    Note You can configure up to five syslog servers.
Results
The syslog server addresses appear in the table.
