SANtricity software
Edit key management server settings
If you configured external key management, you can view and edit the key management server settings at any time.
Steps
  1. Select Settings › System.
  2. Under Security key management, select View/Edit Key Management Server Settings.
  3. Edit information in the following fields:
    • Key management server address — Enter the fully qualified domain name or the IP address (IPv4 or IPv6) of the server used for key management.
    • Key management port number — Enter the port number used for the Key Management Interoperability Protocol (KMIP) communications.
      Optional: you can include another key server by clicking Add Key Server.
  4. Click Save.
