SANtricity software
Operations in progress page
The Operations in Progress page allows you to view a list of long-running operations that are currently running or are in a suspended, stopped, or failed state. You can take action on certain types of operations.
Long-running operations can affect system performance. For some operations, you have the option to stop the operation or change its priority so that more important operations complete first.
Operations that appear on the Operations in Progress page include the following:
Operation Possible status of the operation Actions you can take
Volume copy
Completed
Clear
Volume copy
In progress
  • Change priority
  • Stop
Volume copy
Pending
Clear
Volume copy
Failed
  • Clear
  • Re-copy
Volume copy
Stopped
  • Clear
  • Re-copy
Volume create (thick pool volumes larger than 64TiB only)
In progress
none
Volume delete (thick pool volumes larger than 64TiB only)
In progress
none
Asynchronous mirror group initial synchronization
In progress
Suspend
Suspended
Resume
Synchronous mirroring
In progress
Suspend
Suspended
Resume
Snapshot image rollback
In progress
Cancel
Pending
Cancel
Paused
  • Cancel
  • Resume
Drive evacuation
In progress
Cancel (depends on the drive evacuation type)
Add capacity to pool or volume group
In progress
none
Change a RAID level for a volume
In progress
none
Reduce capacity for a pool
In progress
none
Thin volume reclamation
In progress
none
Check the time remaining on an instant availability format (IAF) operation for pool volumes
In progress
none
Check the data redundancy of a volume group
In progress
none
Defragment a volume group
In progress
none
Initialize a volume
In progress
none
Increase capacity for a volume
In progress
none
Change segment size for a volume
In progress
none
Drive copy
In progress
none
Data reconstruction
In progress
none
Copyback
In progress
none
Drive Erase
In progress
none
Remote storage import
In progress
  • Change priority
  • Stop
Stopped
  • Resume
  • Disconnect
Failed
  • Resume
  • Disconnect
Completed
Disconnect
