Learn about the SANtricity System Manager operations in progress page
The Operations in Progress page allows you to view a list of long-running operations that are currently running or are in a suspended, stopped, or failed state. You can take action on certain types of operations.
Long-running operations can affect system performance. For some operations, you have the option to stop the operation or change its priority so that more important operations complete first.
Operations that appear on the Operations in Progress page include the following:
| Operation | Possible status of the operation | Actions you can take |
Volume copy |
Completed |
Clear |
Volume copy |
In progress |
Volume copy |
Pending |
Clear |
Volume copy |
Failed |
Volume copy |
Stopped |
Volume create (thick pool volumes larger than 64TiB only) |
In progress |
none |
Volume delete (thick pool volumes larger than 64TiB only) |
In progress |
none |
Asynchronous mirror group initial synchronization |
In progress |
Suspend |
Suspended |
Resume |
Synchronous mirroring |
In progress |
Suspend |
Suspended |
Resume |
Snapshot image rollback |
In progress |
Cancel |
Pending |
Cancel |
Paused |
Drive evacuation |
In progress |
Cancel (depends on the drive evacuation type) |
Add capacity to pool or volume group |
In progress |
none |
Change a RAID level for a volume |
In progress |
none |
Reduce capacity for a pool |
In progress |
none |
Thin volume reclamation |
In progress |
none |
Check the time remaining on an instant availability format (IAF) operation for pool volumes |
In progress |
none |
Check the data redundancy of a volume group |
In progress |
none |
Defragment a volume group |
In progress |
none |
Initialize a volume |
In progress |
none |
Increase capacity for a volume |
In progress |
none |
Change segment size for a volume |
In progress |
none |
Drive copy |
In progress |
none |
Data reconstruction |
In progress |
none |
Copyback |
In progress |
none |
Drive Erase |
In progress |
none |
Remote storage import |
In progress |
Stopped |
Failed |
Completed |
Disconnect |
