View and act on operations in progress
To view and take action on long-running operations, use the Operations in Progress page.
For each operation listed on the Operations in Progress page, a percentage of completion and estimated time remaining to complete the operation are shown. In some cases, you can stop an operation or place it at a higher or lower priority. You can also clear a completed Volume Copy operation from the list.
On the Home page, select Show operations in progress.
The Operations in Progress page appears.
If desired, use the links in the Actions column to stop or change priority for an operation.
Read all cautionary text provided in the dialog boxes, particularly when stopping an operation.
You can stop a volume copy operation or change its priority.
Once a volume copy operation is complete, you can select Clear to remove it from the list.
At the top of the Home page, an informational message and yellow wrench icon appear when an operation is complete. This message includes a link that allows you to clear the operation from the Operations in Progress page.
Operations that appear on the Operations in Progress page include the following:
| Operation | Possible status of the operation | Actions you can take |
Volume copy |
Completed |
Clear |
Volume copy |
In progress |
Volume copy |
Pending |
Clear |
Volume copy |
Failed |
Volume copy |
Stopped |
Volume create (thick pool volumes larger than 64TiB only) |
In progress |
none |
Volume delete (thick pool volumes larger than 64TiB only) |
In progress |
none |
Asynchronous mirror group initial synchronization |
In progress |
Suspend |
Suspended |
Resume |
Synchronous mirroring |
In progress |
Suspend |
Suspended |
Resume |
Snapshot image rollback |
In progress |
Cancel |
Pending |
Cancel |
Paused |
Drive evacuation |
In progress |
Cancel (depends on the drive evacuation type) |
Add capacity to pool or volume group |
In progress |
none |
Change a RAID level for a volume |
In progress |
none |
Reduce capacity for a pool |
In progress |
none |
Thin volume reclamation |
In progress |
none |
Check the time remaining on an instant availability format (IAF) operation for pool volumes |
In progress |
none |
Check the data redundancy of a volume group |
In progress |
none |
Defragment a volume group |
In progress |
none |
Initialize a volume |
In progress |
none |
Increase capacity for a volume |
In progress |
none |
Change segment size for a volume |
In progress |
none |
Drive copy |
In progress |
none |
Data reconstruction |
In progress |
none |
Copyback |
In progress |
none |
Drive Erase |
In progress |
none |
Remote storage import |
In progress |
Stopped |
Failed |
Completed |
Disconnect |
