SANtricity software
View and act on operations in progress for SANtricity System Manager
Contributors netapp-jolieg netapp-driley
To view and take action on long-running operations, use the Operations in Progress page.
About this task
For each operation listed on the Operations in Progress page, a percentage of completion and estimated time remaining to complete the operation are shown. In some cases, you can stop an operation or place it at a higher or lower priority. You can also clear a completed Volume Copy operation from the list.
Steps
  1. From the left panel, select menu:Monitoring[Operations in progress].
    The Operations in Progress page appears.
  2. If desired, use the links in the Actions column to stop or change priority for an operation.
    Caution
    Read all cautionary text provided in the dialog boxes, particularly when stopping an operation.
    You can stop a volume copy operation or change its priority.
  3. Once a volume copy operation is complete, you can select Clear to remove it from the list.
    An informational message and yellow wrench icon appear in the Notifications area, available through the bell icon in the upper corner of the window, when an operation is complete. This message includes a link that allows you to clear the operation from the Operations in Progress page.
Operations that appear on the Operations in Progress page include the following:
Operation Possible status of the operation Actions you can take
Volume copy
Completed
Clear
Volume copy
In progress
  • Change priority
  • Stop
Volume copy
Pending
Clear
Volume copy
Failed
  • Clear
  • Re-copy
Volume copy
Stopped
  • Clear
  • Re-copy
Volume create (thick pool volumes larger than 64TiB only)
In progress
none
Volume delete (thick pool volumes larger than 64TiB only)
In progress
none
Asynchronous mirror group initial synchronization
In progress
Suspend
Suspended
Resume
Synchronous mirroring
In progress
Suspend
Suspended
Resume
Snapshot image rollback
In progress
Cancel
Pending
Cancel
Paused
  • Cancel
  • Resume
Drive evacuation
In progress
Cancel (depends on the drive evacuation type)
Add capacity to pool or volume group
In progress
none
Change a RAID level for a volume
In progress
none
Reduce capacity for a pool
In progress
none
Thin volume reclamation
In progress
none
Check the time remaining on an instant availability format (IAF) operation for pool volumes
In progress
none
Check the data redundancy of a volume group
In progress
none
Defragment a volume group
In progress
none
Initialize a volume
In progress
none
Increase capacity for a volume
In progress
none
Change segment size for a volume
In progress
none
Drive copy
In progress
none
Data reconstruction
In progress
none
Copyback
In progress
none
Drive Erase
In progress
none
Remote storage import
In progress
  • Change priority
  • Stop
Stopped
  • Resume
  • Disconnect
Failed
  • Resume
  • Disconnect
Completed
Disconnect
