Decide whether to use a pool or a volume group
You can create volumes using either a pool or a volume group. The best selection depends primarily on the key storage requirements such as the expected I/O workload, the performance requirements, and the data protection requirements.
Reasons to choose a pool or volume group
Choose a pool
If you need faster drive rebuilds and simplified storage administration, require thin volumes, and/or have a highly random workload.
If you want to distribute the data for each volume randomly across a set of drives that comprise the pool.
You cannot set or change the RAID level of pools or the volumes in the pools. Pools use RAID level 6.
Choose a volume group
If you need maximum system bandwidth, the ability to tune storage settings, and a highly sequential workload.
If you want to distribute the data across the drives based on a RAID level. You can specify the RAID level when you create the volume group.
If you want to write the data for each volume sequentially across the set of drives that comprise the volume group.
 Because pools can co-exist with volume groups, a storage array can contain both pools and volume groups.  |
Feature differences between pools and volume groups
The following table provides a feature comparison between volume groups and pools.
| Use | Pool | Volume group |
Workload random  |
Better  |
Good  |
Workload sequential  |
Good  |
Better  |
Drive rebuild time  |
Faster  |
Slower  |
Performance (optimal mode)  |
Good: Best for small block, random workload.  |
Good: Best for large block, sequential workloads  |
Performance (drive rebuild mode)  |
Better: Usually better than RAID 6  |
Degraded: Up to 40% drop in performance  |
Multiple drive failures  |
Greater data protection: Faster, prioritized rebuilds  |
Less data protection: Slow rebuilds, greater risk of data loss  |
Adding drives  |
Faster: Add to pool on the fly  |
Slower: Requires Dynamic Capacity Expansion operation  |
Thin volumes support  |
Yes  |
No  |
Solid State Disk (SSD) support  |
Yes  |
Yes  |
Simplified administration  |
Yes: No hot spares or RAID settings to configure  |
No: Must allocate hot spares, configure RAID  |
Tunable performance  |
No  |
Yes  |
Functional comparison of pools and volume groups
The function and purpose of a pool and a volume group are the same. Both objects are a set of drives logically grouped together in a storage array and are used to create volumes that a host can access.
The following table helps you decide whether a pool or volume group best suits your storage needs.
| Function | Pool | Volume Group |
Different RAID level supported  |
No. Always RAID 6 in System Manager.  |
Yes. RAID 0, 1, 10, 5, and 6 available.  |
Thin volumes supported  |
Yes  |
No  |
Full disk encryption (FDE) supported  |
Yes  |
Yes  |
Data Assurance (DA) supported  |
Yes  |
Yes  |
Shelf loss protection supported  |
Yes  |
Yes  |
Drawer loss protection supported  |
Yes  |
Yes  |
Mixed drive speeds supported  |
Recommended to be the same, but not required. Slowest drive determines speed for all drives.  |
Mixed drive capacity supported  |
Recommended to be the same, but not required. Smallest drive determines capacity for all drives.  |
Minimum number of drives  |
11  |
Depends on RAID level. RAID 0 needs 1. RAID 1 or 10 needs 2 (requires an even number). RAID 5 minimum is 3. RAID 6 minimum is 5.  |
Maximum number of drives  |
Up to the maximum limit for the storage array  |
RAID 1 and 10—up to the maximum limit of the storage array RAID 5, 6—30 drives  |
Can choose individual drives when creating a volume  |
No  |
Yes  |
Can specify segment size when creating a volume  |
Yes. 128K supported.  |
Yes  |
Can specify I/O characteristics when creating a volume  |
No  |
Yes. File system, database, multimedia, and custom supported.  |
Drive failure protection  |
Uses preservation capacity on each drive in the pool making reconstruction faster.  |
Uses a hot spare drive. Reconstruction is limited by the IOPs of the drive.  |
Warning when reaching capacity limit  |
Yes. Can set an alert when used capacity reaches a percentage of the maximum capacity.  |
No  |
Migration to a different storage array supported  |
No. Requires that you migrate to a volume group first.  |
Yes  |
Dynamic Segment Size (DSS)  |
No  |
Yes  |
Can change RAID level  |
No  |
Yes  |
Volume expansion (increase capacity)  |
Yes  |
Yes  |
Capacity expansion (add capacity)  |
Yes  |
Yes  |
Capacity reduction  |
Yes  |
No  |
 Mixed drive types (HDD, SSD) are not supported for either pools or volume groups.  |
