SANtricity software
Configure iSER over InfiniBand ports in SANtricity System Manager
If your controller includes an iSER over InfiniBand port, you can configure the network connection to the host.
Before you begin
  • Your controller must include an iSER over InfiniBand port; otherwise, the iSER over InfiniBand settings are not available in System Manager.
  • You must know the IP address of the host connection.
Steps
  1. Select Settings  System.
  2. Under iSER over InfiniBand settings, select Configure iSER over InfiniBand ports.
  3. Click the controller with the iSER over InfiniBand port you want to configure. Click Next.
  4. In the drop-down list, select the HIC port you want to configure, and then enter the IP address of the host.
  5. Click Finish.
  6. Reset the iSER over InfiniBand port by clicking Yes.
