SANtricity software
Delete trusted certificates in SANtricity System Manager
You can delete the user-installed certificates previously imported from the Trusted tab.
Before you begin
  • You must be logged in with a user profile that includes Security admin permissions. Otherwise, certificate functions do not appear.
  • If you are updating a trusted certificate with a new version, the updated certificate must be imported before you delete the old certificate.
Caution
You might lose access to a system if you delete a certificate used to authenticate the controllers and another server, such as an LDAP server, before you import a replacement certificate.
About this task
This task describes how to delete user-installed certificates. The pre-installed, self-signed certificates cannot be deleted.
Steps
  1. Select Settings › Certificates.
  2. Select the Trusted tab.
    The table shows the storage array's trusted certificates.
  3. From the table, select the certificate you want to remove.
  4. Click Uncommon Tasks › Delete.
    A Confirm Delete Trusted Certificate dialog box opens.
  5. Type delete in the field, and then click Delete.
