Delete trusted certificates in SANtricity System Manager
You can delete the user-installed certificates previously imported from the Trusted tab.
You must be logged in with a user profile that includes Security admin permissions. Otherwise, certificate functions do not appear.
If you are updating a trusted certificate with a new version, the updated certificate must be imported before you delete the old certificate.
You might lose access to a system if you delete a certificate used to authenticate the controllers and another server, such as an LDAP server, before you import a replacement certificate. |
This task describes how to delete user-installed certificates. The pre-installed, self-signed certificates cannot be deleted.
From the left panel, select .
The table shows the storage array's trusted certificates.
From the table, select the certificate you want to remove.
Click .
A Confirm Delete Trusted Certificate dialog box opens.
Type
deletein the field, and then click Delete.
