SANtricity software
Learn about pools and volume groups in SANtricity software
You can create volumes using either a pool or a volume group. The best selection depends primarily on the key storage requirements such as the expected I/O workload, the performance requirements, and the data protection requirements.
Reasons to choose a pool or volume group
Choose a pool
  • If you need faster drive rebuilds and simplified storage administration, require thin volumes, and/or have a highly random workload.
  • If you want to distribute the data for each volume randomly across a set of drives that comprise the pool.
    You cannot set or change the RAID level of pools or the volumes in the pools. Pools use RAID level 6.
Choose a volume group
  • If you need maximum system bandwidth, the ability to tune storage settings, and a highly sequential workload.
  • If you want to distribute the data across the drives based on a RAID level. You can specify the RAID level when you create the volume group.
  • If you want to write the data for each volume sequentially across the set of drives that comprise the volume group.
Note
Because pools can co-exist with volume groups, a storage array can contain both pools and volume groups.
Feature differences between pools and volume groups
The following table provides a feature comparison between volume groups and pools.
Use Pool Volume group
Workload random
Better
Good
Workload sequential
Good
Better
Drive rebuild time
Faster
Slower
Performance (optimal mode)
Good: Best for small block, random workload.
Good: Best for large block, sequential workloads
Performance (drive rebuild mode)
Better: Usually better than RAID 6
Degraded: Up to 40% drop in performance
Multiple drive failures
Greater data protection: Faster, prioritized rebuilds
Less data protection: Slow rebuilds, greater risk of data loss
Adding drives
Faster: Add to pool on the fly
Slower: Requires Dynamic Capacity Expansion operation
Thin volumes support
Yes
No
Solid State Disk (SSD) support
Yes
Yes
Simplified administration
Yes: No hot spares or RAID settings to configure
No: Must allocate hot spares, configure RAID
Tunable performance
No
Yes
Functional comparison of pools and volume groups
The function and purpose of a pool and a volume group are the same. Both objects are a set of drives logically grouped together in a storage array and are used to create volumes that a host can access.
The following table helps you decide whether a pool or volume group best suits your storage needs.
Function Pool Volume Group
Different RAID level supported
No. Always RAID 6 in System Manager.
Yes. RAID 0, 1, 10, 5, and 6 available.
Thin volumes supported
Yes
No
Full disk encryption (FDE) supported
Yes
Yes
Data Assurance (DA) supported
Yes
Yes
Shelf loss protection supported
Yes
Yes
Drawer loss protection supported
Yes
Yes
Mixed drive speeds supported
Recommended to be the same, but not required. Slowest drive determines speed for all drives.
Mixed drive capacity supported
Recommended to be the same, but not required. Smallest drive determines capacity for all drives.
Minimum number of drives
11
Depends on RAID level. RAID 0 needs 1. RAID 1 or 10 needs 2 (requires an even number). RAID 5 minimum is 3. RAID 6 minimum is 5.
Maximum number of drives
Up to the maximum limit for the storage array
RAID 1 and 10—​up to the maximum limit of the storage array RAID 5, 6—​30 drives
Can choose individual drives when creating a volume
No
Yes
Can specify segment size when creating a volume
Yes. 128K supported.
Yes
Can specify I/O characteristics when creating a volume
No
Yes. File system, database, multimedia, and custom supported.
Drive failure protection
Uses preservation capacity on each drive in the pool making reconstruction faster.
Uses a hot spare drive. Reconstruction is limited by the IOPs of the drive.
Warning when reaching capacity limit
Yes. Can set an alert when used capacity reaches a percentage of the maximum capacity.
No
Migration to a different storage array supported
No. Requires that you migrate to a volume group first.
Yes
Dynamic Segment Size (DSS)
No
Yes
Can change RAID level
No
Yes
Volume expansion (increase capacity)
Yes
Yes
Capacity expansion (add capacity)
Yes
Yes
Capacity reduction
Yes
No
Note
Mixed drive types (HDD, SSD) are not supported for either pools or volume groups.
