SANtricity software
Learn about pools and volume groups in SANtricity System Manager
You can create logical storage capacity from a subset of unassigned drives in your storage array. This logical capacity can take the form of either a pool or a volume group, depending on the needs of your environment.
What are pools and volume groups?
A pool is a set of logically grouped drives. A volume group is a container for volumes with shared characteristics. You can use either a pool or volume group to create volumes accessible to a host.
Learn more:
How do you create pools?
You can allow System Manager to create pools automatically when it detects unassigned capacity in a storage array. Alternatively, when automatic creation cannot determine the best configuration, you can create pools manually from Storage › Pools & Volume Groups.
Learn more:
How do you create volume groups?
You can create volume groups from Storage › Pools & Volume Groups.
Learn more:
Learn more about concepts related to pools and volume groups:
