SANtricity software
Learn about Remote Storage feature requirements in SANtricity software
Before using the Remote Storage feature, review the following requirements and restrictions.
Supported protocols
The following protocols are supported:
  • iSCSI
  • IPv4
For up-to-date E-Series support and configuration information, see the NetApp Interoperability Matrix Tool.
Hardware requirements
The E-Series storage system must include:
  • Two controllers (duplex mode)
  • iSCSI connections for both E-Series controllers to communicate with the remote storage system through one or more iSCSI connections
  • SANtricity OS 11.71 or greater
  • Remote Storage feature enabled in the Submodel ID (SMID)
The remote system can be either an E-Series storage system or a system from another vendor. It must include:
  • iSCSI-capable interfaces
Restrictions
The Remote Storage feature has the following restrictions:
  • Mirroring must be disabled.
  • Destination volume on the E-Series system must not have snapshots.
  • Destination volume on the E-Series system must not be mapped to any hosts before the import is started.
  • Destination volume on the E-Series system must have resource-provisioning disabled.
  • Direct mappings of the remote storage volume to a host or multiple hosts is not supported.
  • Web Services Proxy is not supported.
  • iSCSI CHAP secrets are not supported.
  • SMcli is not supported.
  • VMware Datastore is not supported.
  • Only one storage system in the relationship/import pair can be upgraded at a time when there is an import pair present.
