Remote Storage feature requirements in SANtricity software
Before using the Remote Storage feature, review the following requirements and restrictions.
Supported protocols
The following protocols are supported:
iSCSI
IPv4
For up-to-date E-Series support and configuration information, see the NetApp Interoperability Matrix Tool.
Hardware requirements
The E-Series storage system must include:
Two controllers (duplex mode)
iSCSI connections for both E-Series controllers to communicate with the remote storage system through one or more iSCSI connections
SANtricity OS 11.71 or greater
Remote Storage feature enabled in the Submodel ID (SMID)
The remote system can be either an E-Series storage system or a system from another vendor. It must include:
iSCSI-capable interfaces
Restrictions
The Remote Storage feature has the following restrictions:
Mirroring must be disabled.
Destination volume on the E-Series system must not have snapshots.
Destination volume on the E-Series system must not be mapped to any hosts before the import is started.
Destination volume on the E-Series system must have resource-provisioning disabled.
Direct mappings of the remote storage volume to a host or multiple hosts is not supported.
Web Services Proxy is not supported.
iSCSI CHAP secrets are not supported.
SMcli is not supported.
VMware Datastore is not supported.
Only one storage system in the relationship/import pair can be upgraded at a time when there is an import pair present.
