SANtricity software
Place a controller offline in SANtricity System Manager
Contributors netapp-driley netapp-jolieg
If you are instructed to do so, you can place a controller offline.
Before you begin
  • Your storage array must have two controllers. The controller that you are not placing offline must be online (in the optimal state).
  • Make sure that no volumes are in use or that you have a multipath driver installed on all hosts using these volumes.
About this task
Caution
Do not place a controller offline unless you are instructed to do so by the Recovery Guru or technical support.
Steps
  1. From the left panel, select menu:Hardware[Controllers and components].
  2. Click the controller that you want to place offline.
    The controller's context menu appears.
  3. Select Place offline, and confirm that you want to perform the operation.
Results
It might take several minutes for System Manager to update the controller's status to offline. Do not begin any other operations until after the status has been updated.
