Turn on a shelf locator light in SANtricity System Manager
To find the physical location of a shelf shown on the Hardware page, you can turn on the shelf's locator light.
Steps
From the left panel, select menu:Hardware[Controllers and components].
Select the drop-down list for the Controller Shelf or Drive Shelf, and then select Turn on locator light.
The locator light for the shelf turns on.
When you have physically located the shelf, return to the dialog box and select Turn off.
