SANtricity software
Learn about the SANtricity System Manager interface
Contributors netapp-jolieg netapp-driley Vaishnavi-Totewar
SANtricity System Manager is a web-based interface that allows you to manage a storage array in a single view.
Dashboard
The Dashboard provides a summary view for the daily management of your storage array. When you log into System Manager, the Dashboard is the first screen displayed.
The dashboard view comprises three summary areas that contain key information about the state and health of your storage array. You can find more information from the summary area.
Area Description
Performance
The Performance area allows you to compare and contrast resource usage over time. You can view a storage array's performance metrics for response time (IOPS), transfer rates (MiB/s), and the amount of processing capacity being used (CPU).
Capacity
The Capacity area displays a chart view of the allocated capacity, free storage capacity, and unassigned storage capacity in your storage array.
Storage Hierarchy
The Storage Hierarchy area provides an organized view of the various hardware components and storage objects managed by your storage array. Click the drop-down arrow to perform a certain action on that hardware component or storage object.
Notifications area
The Notifications area is available through the bell icon in the upper corner of the window. The Notifications area displays problem notifications that indicate the status of the storage array and its components. In addition, this section displays automated alerts that can help you troubleshoot issues before it affects other areas of your storage environment.
Interface settings
You can change display preferences and other settings from the main interface.
User logins and passwords
The current user logged into the system is shown in the user settings.
For further information on users and passwords, see:
