Turn on storage array locator lights in SANtricity System Manager
To find the physical location of a storage array in a cabinet, you can turn on its locator (LED) lights.
Steps
From the left panel, select System.
Under General, click Turn on storage array locator lights.
The Turn on locator lights dialog box opens, and the corresponding storage array's locator lights turn on.
When you have physically located the storage array, return to the dialog box and select Turn off.
Results
The locator lights turn off, and the dialog box closes.
