What else do I need to do to configure or diagnose NVMe over InfiniBand?
The following table lists the System Manager functions that you can use to configure and manage NVMe over InfiniBand sessions.
Note
The NVMe over InfiniBand settings are available only if your storage array’s controller includes an NVMe over InfiniBand port.
Action Location
Configure NVMe over InfiniBand ports
  1. Select Hardware.
  2. Select Show back of shelf.
  3. Select a controller.
  4. Select Configure NVMe over InfiniBand ports.
or
  1. Select Settings  System.
  2. Scroll down to NVMe over InfiniBand settings, and then select Configure NVMe over InfiniBand Ports.
View NVMe over InfiniBand statistics
  2. Scroll down to NVMe over InfiniBand settings, and then select View NVMe over Fabrics Statistics.
