Element Software
Create and manage user accounts by using NetApp Hybrid Cloud Control
Contributors netapp-pcarriga
In Element-based storage systems, authoritative cluster users can be created to enable login access to NetApp Hybrid Cloud Control depending on the permissions you want to grant "Administrator" or "Read-only" users. In addition to cluster users, there are also volume accounts, which enable clients to connect to volumes on a storage node.
Manage the following types of accounts:
Enable LDAP
To use LDAP for any user account, you must first enable LDAP.
Steps
  1. Log in to NetApp Hybrid Cloud Control by providing the Element storage cluster administrator credentials.
  2. From the Dashboard, select on the top right Options icon and select User Management.
  3. From the Users page, select Configure LDAP.
  4. Define your LDAP configuration.
  5. Select the authentication type of Search and Bind or Direct Bind.
  6. Before you save the changes, select Test LDAP Log In at the top of the page, enter the user name and password of a user you know exists, and select Test.
  7. Select Save.
Manage authoritative cluster accounts
Authoritative user accounts are managed from the top right menu User Management option in NetApp Hybrid Cloud Control. These types of accounts enable you to authenticate against any storage asset associated with a NetApp Hybrid Cloud Control instance of nodes and clusters. With this account, you can manage volumes, accounts, access groups, and more across all clusters.
Create an authoritative cluster account
You can create an account by using NetApp Hybrid Cloud Control.
This account can be used to log in to the Hybrid Cloud Control, the per-node UI for the cluster, and the storage cluster in NetApp Element software.
Steps
  3. Select Create User.
  4. Select the authentication type of cluster or LDAP.
  5. Complete one of the following:
    • If you selected LDAP, enter the DN.
      Tip To use LDAP, you must first enable LDAP or LDAPS. See Enable LDAP.
    • If you selected Cluster as the Auth Type, enter a name and password for the new account.
  6. Select either Administrator or Read-only permissions.
    Tip To view the permissions from NetApp Element software, select Show legacy permissions. If you select a subset of these permissions, the account is assigned Read-only permissions. If you select all legacy permissions, the account is assigned Administrator permissions.
    Tip To ensure that all children of a group inherit permissions, create a DN organization admin group in the LDAP server. All the children accounts of that group will inherit those permissions.
  7. Check the box indicating that "I have read and accept the NetApp End User License Agreement."
  8. Select Create User.
Edit an authoritative cluster account
You can change the permissions or password on a user account by using NetApp Hybrid Cloud Control.
Steps
  2. From the Dashboard, select on the icon in the top right and select User Management.
  3. Optionally filter the list of user accounts by selecting Cluster, LDAP, or Idp.
    If you configured users on the storage cluster with LDAP, those accounts show a User Type of "LDAP." If you configured users on the storage cluster with Idp, those accounts show a User Type of "Idp."
  4. In the Actions column in the table, expand the menu for the account and select Edit.
  5. Make changes as needed.
  6. Select Save.
  7. Log out of NetApp Hybrid Cloud Control.
    Note It might take the NetApp Hybrid Cloud Control UI up to 2 minutes to refresh the inventory. To manually refresh inventory, access the REST API UI inventory service https://[management node IP]/inventory/1/ and run GET /installations​/{id} for the cluster.
  8. Log into NetApp Hybrid Cloud Control.
Delete an authoritative user account
You can delete one or more accounts when it is no longer needed. You can delete an LDAP user account.
You cannot delete the primary administrator user account for the authoritative cluster.
Steps
  3. In the Actions column in the Users table, expand the menu for the account and select Delete.
  4. Confirm the deletion by selecting Yes.
Manage volume accounts
Volume accounts are managed within the NetApp Hybrid Cloud Control Volumes table. These accounts are specific only to the storage cluster on which they were created. These types of accounts enable you to set permissions on volumes across the network, but have no effect outside of those volumes.
A volume account contains the CHAP authentication required to access the volumes assigned to it.
Create a volume account
Create an account specific to this volume.
Steps
  2. From the Dashboard, select Storage > Volumes.
  3. Select the Accounts tab.
  4. Select the Create Account button.
  5. Enter a name for the new account.
  6. In the CHAP Settings section, enter the following information:
    • Initiator Secret for CHAP node session authentication
    • Target Secret for CHAP node session authentication
      Note To auto-generate either password, leave the credential fields blank.
  7. Select Create Account.
Edit a volume account
You can change the CHAP info and change whether an account is active or locked.
Important Deleting or locking an account associated with the management node results in an inaccessible management node.
Steps
  6. Confirm the changes by selecting Yes.
Delete a volume account
Delete an account that you no longer need.
Before you delete a volume account, delete and purge any volumes associated with the account first.
Note Persistent volumes that are associated with management services are assigned to a new account during installation or upgrade. If you are using persistent volumes, do not modify or delete the volumes or their associated account. If you do delete these accounts, you could render your management node unusable.
Steps
  4. In the Actions column in the table, expand the menu for the account and select Delete.
  5. Confirm the deletion by selecting Yes.
Find more information
