Element Software
Network settings details from the per-node UI
Contributors netapp-pcarriga netapp-dbagwell
You can change the storage node network settings to give the node a new set of network attributes.
You can see the network settings for a storage node on the Network Settings page when you log in to the node (https://<node IP>:442/hcc/node/network-settings). You can select either Bond1G (management) or Bond10G (storage) settings. The following list describes the settings that you can modify when a storage node is in Available, Pending, or Active state:
  • Method
    The method used to configure the interface. Possible methods:
    • loopback: Used to define the IPv4 loopback interface.
    • manual: Used to define interfaces for which no configuration is done by default.
    • dhcp: Used to obtain an IP address via DHCP.
    • static: Used to define Ethernet interfaces with statically allocated IPv4 addresses.
  • Link Speed
    The speed negotiated by the virtual NIC.
  • IPv4 Address
    The IPv4 address for the eth0 network.
  • IPv4 Subnet Mask
    Address subdivisions of the IPv4 network.
  • IPv4 Gateway Address
    Router network address to send packets out of the local network.
  • IPv6 Address
    The IPv6 address for the eth0 network.
  • IPv6 Gateway Address
  • MTU
    Largest packet size that a network protocol can transmit. Must be greater than or equal to 1500. If you add a second storage NIC, the value should be 9000.
  • DNS Servers
    Network interface used for cluster communication.
  • Search Domains
    Search for additional MAC addresses available to the system.
  • Bond Mode
    Can be one of the following modes:
    • ActivePassive (default)
    • ALB
    • LACP
  • Status
    Possible values:
    • UpAndRunning
    • Down
    • Up
  • Virtual Network Tag
    Tag assigned when the virtual network was created.
  • Routes
    Static routes to specific hosts or networks via the associated interface the routes are configured to use.
