Enable virtual routing and forwarding
You can enable virtual routing and forwarding (VRF), which allows multiple instances of a routing table to exist in a router and work simultaneously. This functionality is available for storage networks only.
You can enable VRF only at the time of creating a VLAN. If you want to switch back to non-VRF, you must delete and re-create the VLAN.
Click Cluster > Network.
To enable VRF on a new VLAN, select Create VLAN.
Enter relevant information for the new VRF/VLAN. See Adding a virtual network.
Select the Enable VRF check box.
Optional: Enter a gateway.
Click Create VLAN.
