The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Enable virtual routing and forwarding
PDF of this doc site
Manage storage with Element software
Protect your data
Replication between NetApp Element software and ONTAP (ONTAP CLI)
Creating your file...
Your file is ready
You can enable virtual routing and forwarding (VRF), which allows multiple instances of a routing table to exist in a router and work simultaneously. This functionality is available for storage networks only.
You can enable VRF only at the time of creating a VLAN. If you want to switch back to non-VRF, you must delete and re-create the VLAN.
Click Cluster > Network.
To enable VRF on a new VLAN, select Create VLAN.
Enter relevant information for the new VRF/VLAN. See Adding a virtual network.
Select the Enable VRF check box.
Optional: Enter a gateway.
Click Create VLAN.
