Change the management node default SSL certificate
PDF of this doc site
Manage storage with Element software
- Protect your data
Creating your file...
You can change the default SSL certificate and private key of the management node using the NetApp Element API.
When you configure a management node, it creates a unique self-signed Secure Sockets Layer (SSL) certificate and private key that is used for all HTTPS communication by way of the the Element UI, per-node UI, or APIs. Element software supports self-signed certificates as well as certificates that are issued and verified by a trusted Certificate Authority (CA).
You can use the following API methods to get more information about the default SSL certificate and make changes.
GetNodeSSLCertificate
You can use the GetNodeSSLCertificate method to retrieve information about the currently installed SSL certificate including all certificate details.
SetNodeSSLCertificate
You can use the SetNodeSSLCertificate method to set the cluster and per-node SSL certificates to the certificate and private key you supply. The system validates the certificate and private key to prevent an invalid certificate from being applied.
RemoveNodeSSLCertificate
This RemoveNodeSSLCertificate method removes the currently installed SSL certificate and private key. The cluster then generates a new self-signed certificate and private key.
