Protocol endpoints details
PDF of this doc site
Manage storage with Element software
- Protect your data
Creating your file...
The Protocol Endpoints page on the VVols tab provides protocol endpoint information.
Primary Provider ID
The ID of the primary protocol endpoint provider.
Secondary Provider ID
The ID of the secondary protocol endpoint provider.
Protocol Endpoint ID
The UUID of the protocol endpoint.
Protocol Endpoint State
The status of the protocol endpoint. Possible values are as follows:
Active: The protocol endpoint is in use.
Start: The protocol endpoint is starting.
Failover: The protocol endpoint has failed over.
Reserved: The protocol endpoint is reserved.
Provider Type
The type of the protocol endpoint's provider. Possible values are as follows:
Primary
Secondary
SCSI NAA Device ID
The globally unique SCSI device identifier for the protocol endpoint in NAA IEEE Registered Extended Format.
