Fibre Channel session details
You can find information about the active Fibre Channel (FC) sessions that are connected to the cluster.
The following list describes the information you can find about the FC sessions connected to the cluster:
Node ID
The node hosting the session for the connection.
Node Name
System-generated node name.
Initiator ID
A system-generated ID for the initiator.
Initiator WWPN
The initiating worldwide port name.
Initiator Alias
An optional name for the initiator that makes finding the initiator easier when in a long list.
Target WWPN
The target worldwide port name.
Volume Access Group
Name of the volume access group that the session belongs to.
Volume Access Group ID
System-generated ID for the access group.
