Element Software
Fibre Channel session details
Contributors netapp-pcarriga
You can find information about the active Fibre Channel (FC) sessions that are connected to the cluster.
The following list describes the information you can find about the FC sessions connected to the cluster:
  • Node ID
    The node hosting the session for the connection.
  • Node Name
    System-generated node name.
  • Initiator ID
    A system-generated ID for the initiator.
  • Initiator WWPN
    The initiating worldwide port name.
  • Initiator Alias
    An optional name for the initiator that makes finding the initiator easier when in a long list.
  • Target WWPN
    The target worldwide port name.
  • Volume Access Group
    Name of the volume access group that the session belongs to.
  • Volume Access Group ID
    System-generated ID for the access group.
