Cluster settings details from the per-node UI
PDF of this doc site
Manage storage with Element software
- Protect your data
Creating your file...
You can verify cluster settings for a storage node after cluster configuration and modify the node hostname.
The following list describes the cluster settings for a storage node indicated from the Cluster Settings page of the per-node UI (https://<node IP>:442/hcc/node/cluster-settings).
Role
Role the node has in the cluster. Possible values:
Storage: Storage or Fibre Channel node.
Management: Node is a management node.
Hostname
Name of the node.
Cluster
Name of the cluster.
Cluster Membership
State of the node. Possible values:
Available: The node has no associated cluster name and is not yet part of a cluster.
Pending: The node is configured and can be added to a designated cluster. Authentication is not required to access the node.
PendingActive: The system is in the process of installing compatible software on the node. When complete, the node will move to the Active state.
Active: The node is participating in a cluster. Authentication is required to modify the node.
Version
Version of the Element software running on the node.
Ensemble
Nodes that are part of the database ensemble.
Node ID
ID assigned when a node is added to the cluster.
Cluster Interface
Network interface used for cluster communication.
Management Interface
Management network interface. This defaults to Bond1G but can also use Bond10G.
Storage Interface
Storage network interface using Bond10G.
Encryption Capable
Indicates whether or not the node supports drive encryption.
