Element Software
Cluster settings details from the per-node UI
You can verify cluster settings for a storage node after cluster configuration and modify the node hostname.
The following list describes the cluster settings for a storage node indicated from the Cluster Settings page of the per-node UI (https://<node IP>:442/hcc/node/cluster-settings).
  • Role
    Role the node has in the cluster. Possible values:
    • Storage: Storage or Fibre Channel node.
    • Management: Node is a management node.
  • Hostname
    Name of the node.
  • Cluster
    Name of the cluster.
  • Cluster Membership
    State of the node. Possible values:
    • Available: The node has no associated cluster name and is not yet part of a cluster.
    • Pending: The node is configured and can be added to a designated cluster. Authentication is not required to access the node.
    • PendingActive: The system is in the process of installing compatible software on the node. When complete, the node will move to the Active state.
    • Active: The node is participating in a cluster. Authentication is required to modify the node.
  • Version
    Version of the Element software running on the node.
  • Ensemble
    Nodes that are part of the database ensemble.
  • Node ID
    ID assigned when a node is added to the cluster.
  • Cluster Interface
    Network interface used for cluster communication.
  • Management Interface
    Management network interface. This defaults to Bond1G but can also use Bond10G.
  • Storage Interface
    Storage network interface using Bond10G.
  • Encryption Capable
    Indicates whether or not the node supports drive encryption.
