Element Software
Enable SnapMirror on the Element source volume
You must enable SnapMirror on the Element source volume before you can create a replication relationship. You can only perform this task in the Element software web UI or using the ModifyVolume and ModifyVolumes API methods.
Before you begin
  • You must have enabled SnapMirror on the Element cluster.
  • The volume block size must be 512 bytes.
  • The volume must not be participating in Element remote replication.
  • The volume access type must not be “Replication Target”.
About this task
The procedure below assumes the volume already exists. You can also enable SnapMirror when you create or clone a volume.
Steps
  1. Select Management > Volumes.
  2. Select the Actions icon button for the volume.
  3. In the drop-down menu, select Edit.
  4. In the Edit Volume dialog, select Enable SnapMirror.
  5. Select Save Changes.
