Enable SnapMirror on the Element source volume
You must enable SnapMirror on the Element source volume before you can create a replication relationship. You can only perform this task in the Element software web UI or using the ModifyVolume and ModifyVolumes API methods.
Before you begin
You must have enabled SnapMirror on the Element cluster.
The volume block size must be 512 bytes.
The volume must not be participating in Element remote replication.
The volume access type must not be “Replication Target”.
About this task
The procedure below assumes the volume already exists. You can also enable SnapMirror when you create or clone a volume.
Steps
Select Management > Volumes.
Select the
button for the volume. -
In the drop-down menu, select Edit.
In the Edit Volume dialog, select Enable SnapMirror.
Select Save Changes.
