The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Configure cluster settings
PDF of this doc site
Manage storage with Element software
Protect your data
Perform replication between NetApp Element software and ONTAP (ONTAP CLI)
Creating your file...
Your file is ready
You can view and change cluster-wide settings and perform cluster-specific tasks from the Cluster tab of the Element UI.
You can configure settings such as cluster fullness threshold, support access, encryption at rest, virtual volumes, SnapMirror, and NTP broadcast client.
