The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Management node UI overview
PDF of this doc site
Manage storage with Element software
Protect your data
Perform replication between NetApp Element software and ONTAP (ONTAP CLI)
Creating your file...
Your file is ready
With the management node UI (https://<ManagementNodeIP>:442
), you can make changes to network and cluster settings, run system tests, or use system utilities.
Tasks you can perform with the management node UI:
