Create a SnapMirror endpoint
You must create a SnapMirror endpoint before you can create a replication relationship. You can only perform this task in the Element software web UI or using the SnapMirror API methods.
Before you begin
You must have enabled SnapMirror on the Element cluster.
Steps
Click Data Protection > SnapMirror Endpoints.
Click Create Endpoint.
In the Create a New Endpoint dialog, enter the ONTAP cluster management IP address.
Enter the user ID and password of the ONTAP cluster administrator.
