Enable encryption at rest
PDF of this doc site
Manage storage with Element software
- Protect your data
Creating your file...
Your file is ready
You can enable and disable cluster-wide encryption at rest. This feature is not enabled by default. To support FIPS drives, you must enable encryption at rest.
In the NetApp Element software UI, click Cluster > Settings.
Click Enable Encryption at Rest.
