The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Enable encryption at rest
PDF of this doc site
Manage storage with Element software
Creating your file...
Your file is ready
You can enable and disable cluster-wide encryption at rest. This feature is not enabled by default. To support FIPS drives, you must enable encryption at rest.
In the NetApp Element software UI, click Cluster > Settings.
Click Enable Encryption at Rest.
