Element Software
iSCSI session details
You can view information about the iSCSI sessions that are connected to the cluster.
The following list describes the information that you can find about the iSCSI sessions:
  • Node
    The node hosting the primary metadata partition for the volume.
  • Account
    The name of the account that owns the volume. If value is blank, a dash (-) is displayed.
  • Volume
    The volume name identified on the node.
  • Volume ID
    ID of the volume associated with the Target IQN.
  • Initiator ID
    A system-generated ID for the initiator.
  • Initiator Alias
    An optional name for the initiator that makes finding the initiator easier when in a long list.
  • Initator IP
    The IP address of the endpoint that initiates the session.
  • Initiator IQN
    The IQN of the endpoint that initiates the session.
  • Target IP
    The IP address of the node hosting the volume.
  • Target IQN
    The IQN of the volume.
  • Created On
    Date the session was established.
